A little run down on what the parameters are:
Max lift : .800I/.785E
Target installed ht: 2.050" (Isky 9998-RAD)
Current valve length: 5.344I/TBD
So far with the intake valves that came in the head I am getting about 2.02 " IH on the intake with no spring cup installed and a +.050 lock. I think a 5.444" OAL might work f i used a standard height lock and Isky .045" spring seat. Only issue thus far is nobody makes a 2.25" diameter valve, only a 2.30. I might call Manley and see if they can do us up a set of Super Alloy ex. and Severe Duty Intakes. I am also consodering coated Ti is I could find a deal lol.
So many details to be ironed out...
