Any offset intake lifter is way better than none on low decks with any offset intake rocker heads On my current bracket motor with Jesel paired shaft rockers I started it off with pushrod oiling with Comp Cams lifters with no oil band, I added spray bar oiling also but I'm going to remove that now as the pushrod oiling is doing way better than I thought it would
Interesting. I'll give you call once I know enough to have an intelligent conversation lol. : D
