Originally Posted by GODSCOUNTRY340
Didn't know you used that VB in another trans. Since that is a manual shift body you have to block off the governor in the tailshaft. If you don't the trans will attempt to shift on it's own while you are trying to force shift it throughout the valve body, could cause problems.
Confused??
I thought the valve body did that by design?
I do plan on removing the governor now that its off anyway.
Is there something else that is required?
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
