My 74 crew was converted to discs using the pieces off I believe a mid 70's to mid 80's Chevy truck. Everything from the knuckles out, maybe even the stub axles and I'm not sure if you really need the knuckles. So much of that basic Dana 44 stuff is the same between the two.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost conversion. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
