Good info, thanks. Got a little more done today, still showing no charge at the battery so I took the bulkhead connectors apart...again...pulled the instrument panel, cleaned everything, put it all back together, still no charge...ugh...adjusted the emergency brake...that was fun...not. Oh well...back at it tomorrow...
Sorry it didn't fix things for you, but cleaning the bulkhead will serve you well anyhow!
