Got a little more done yesterday, finally got the front drums off, shoes and drums were grooved into each other, what a whipping. The good news is O'Reilly's had all but a couple of the parts local so with any luck I'll have it ready for a test drive today. On a side note...so far I've put a battery, alternator and voltage regulator on and it's still showing discharge on the alt gauge and at the battery the volt tester is only picking up 12.7 volts...any suggestions?
1968 Plymouth GTX
1974 Dodge P/U Long Bed Stepside 318
2019 Ram 2500 6.4, auto, 4WD
