The advantage of a belt drive is removing the harmonic transfer between the crank and the valve train - also a belt will outlast a chain - every chain I have had stretches after a season - belt will last around five years before changing it out for maintenance. I agree there is no real HP gain going belt drive just more accuracy of cam timing and stability.
