I think Jessel is the only current manufacture of belt drives for a BB - on the cam bolts are you using the ARP 12 points? - I have used header bolts in the past and touched the face up with a belt sander. Only time I had an issue was when using the cam button retainer plate. With the cloyes it seams the gear is thicker
