I didn't verify the true coilbind for each, as i recall i went to about .070 by the book. There is no easy way to pressure oil this deal. Jesels are paired on a single solid 5/8 od shaft for each cylinder.
So are my T&D's. Oil goes from the pushrod, through the adjuster, through the rocker, through the bearing. Doug
This is a nice feature the T&D’s have that the Jesel’s don’t.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123 Dealer for Comp Cams/Indy Heads
