Any chance those bronze washers are impeding the oil getting to the bearings?
The bearings had plenty of oil in them when i disassembled the rockers. The info on spring rate increase with very close installed heights is greatly appreciated! I am very close to .050 to coil bind (.060 to .070?) and the rpm i hit once in a while may really put stress on stuff. I have the rev limiter set at 7700 if i recall. Probably better lower it a bit.
