When you change the first gear ratio in the tranny to be lower, steeper(2.45 to 2.77) you end up in high gear sooner as well as in second gear sooner also
A 8 inch converter is suppose to have more torque multiplication in 1st gear than a 9 or 10 inch does
I read a magazine article on this a long, long time ago saying that the 8 inch Opel based race converters had around a 3.25 to 1 ratio compared to the 9 and 10 inch converters which had closer to 2.5 ratio in them
It did NOT mention how long that effect lasted, 3 feet or 160 feet
