Originally Posted By RapidRobert
The upper radiator hose barely has any coolant flow through it; my survivor 69 Charger with completely untouched original 383 has MUCH more pressure/flow in the upper radiator hose.
We're definitely on to something there. I've wondered about the slit head gaskets too but iirc people have said they are OK for the most part. But we certainly have a restricted flow for some reason that has to be what is causing this. can you post a larger pic that shows all the holes from front to rear? (to try & get an idea if the total/overall restriction is somewhere other than the gaskets). I have a good cooling mod read for you on circle track chat, a subset from moparchat (VERY informative) that relates directly to this but one thing at a time.
No the slits are not why, there are thousands of big blocks out there running head gaskets like that.
running up my post count some more .
