The car has no AC or power steering. its just got an alternator (new), fan, and a water pump. The pulleys appear stock. I do not have a fan shroud installed but the new clutched fan is pulling tons of air. I also don't have the hood to radiator seal but I haven't even gotten to driving it really.
At idle, the engine heats steadily up to 220 and hotter if i let it. The water pump has only a few miles on it but its probably 10 years old.I just ran it again and thought I'd check flow. I opened the cap once the temp was past 180 and the coolant flow was very slow. I think I will try a new water pump tomorrow.
I'll be super annoyed if the head gaskets were installed wrong and coolant ports are blocked off.
1970 Barracuda B5 6.1 Hemi/6 speed 1969 Charger survivor in R6 383/727-wrecked 12/24/18 1968 Charger in original burgundy paint "Ribeye" 1968 Charger w/ 6.1L, TR-6060, 9" 1968 Roadrunner w/ 6.1L/6 speed 2011 Dodge Ram w/ 6.7L
