How much does it cost to add a billet front drum, lba valve body, and an ultra-spraig, compared to a similar build with out those safety measures?
quite a bit , drum is US$7 or 800 I think . Sprag around US$100 .
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
