I would like to go with a carbon fiber shield, but not sure it will fit in a Volare/Roadrunner, 440/727.
I am sure a blanket will fit, but not sure about heat build up driving to/from the track of 35 miles each way.
Thanks, John
Just ordered the DJ Safety blanket , specific for TF727 . Got the shorty , I think it only covers up to the pump . But the new trans does also have a billet drum lba etc . Better be ok , I drive it every day
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
