Ive an aa or aaa? I think cope uses his own now? And ive never noticed a delay at the track or street when hooked, if im horsing around and blow the drag radials off I can hear the 1-2 shift in the motor but its not enough to make the tach needle drop, by then im already in 2nd at 7200, about a second and a half but I always run it out when I do and it gently hooks, I never let off abruptly.
Do the data loggers show the delay?
Originally Posted By Clanton
Originally Posted By EV2Bird
I wonder about these new vb'd lba and if they were ever test on a bench or dyno to verify there correct function.[delay in shift 1 to 2 correctly.cause effect]
Are you meaning copes brand or that type VB overall?
Any brand,The racers seem to be the test bed for a new product to work out the bug most of the time.
