Low band apply valve body. Billet steel drum. Bolt in sprag.
At least I hope that will, that's what I have.
others beat me to it ...... If that bolt in sprag is not the $$ A+A or Coan it's a waste of money and time. The generic run of the mill bolt is is to fix a loose outer race. Also as said, if you doesn't have a full manual valve body (NO AUTO SHIFT AT ALL) putting the shifter in 2 still starts the trans in low WITHOUT the band applied, put that auto shift lever in 1 though will apply the band.
It's reverse manual Cope 727, it's going back to him this winter for a freshen up, I'll talk to him.
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
