Page 6 of 9 1 2 3 4 5 6 7 8 9
Re: 727 explosion at Milan last night.... [Re: dvw] #2391306
10/22/17 04:16 PM
10/22/17 04:16 PM
PA
Scully Offline
Scully  Offline
PA
Originally Posted By dvw
If it has a good drum it doesn't matter if the low roller gives up the ghost or not. I've seen low rollers break with low band apply. I have also seen Super Sprag's break.
Doug
The sprag can still break from the shock but the drum wont explode. I broke the sprag in my race car on the line testing at my local track because I broke an axle but still drove the car back to the pits and on to the trailer. It was just 4 days before I had to leave for the Keystone Nats. I had to overnight axles from Strange, repair the trans and set up a new rear as the axle broke at the spline and got into the carrier bearings, all while working a night job as well as my machine shop, 5 am Thurs morn I pulled out for the Keys and ran a good race but I was tired for sure.
Re: 727 explosion at Milan last night.... [Re: dustergirl340] #2391351
10/22/17 06:22 PM
10/22/17 06:22 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
How much does it cost to add a billet front drum, lba valve body, and an ultra-spraig, compared to a similar build with out those safety measures?
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: 727 explosion at Milan last night.... [Re: Hemi_Joel] #2391356
10/22/17 06:32 PM
10/22/17 06:32 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
quite a bit , drum is US$7 or 800 I think . Sprag around US$100 .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: 727 explosion at Milan last night.... [Re: Scully] #2391359
10/22/17 06:39 PM
10/22/17 06:39 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Originally Posted By Scully
The 2-3 shift is all about timing to avoid overlap
In reality you can't avoid all overlap, some is necessary to prevent rpm flare up on the shift. That's why the TF will always be inferior to a trans like the TH400 that has no release/apply cycle.
Re: 727 explosion at Milan last night.... [Re: mopar dave] #2391370
10/22/17 07:11 PM
10/22/17 07:11 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Originally Posted By mopar dave
so why would anyone pay more for the super sprag if they break too? save your money and just install a bolt in stock type then and use an aftermarket drum.
Not to be a smart azz but, I was told years ago that if a human built it it WILL eventually break,, When I built my 727 for the 512 I took all the knowledge that I had learned and applied it, Super sprag and a steel drum and Copes awesome new transbrke VB and a complete re-hash of everything inside the case. up
Re: 727 explosion at Milan last night.... [Re: pittsburghracer] #2391388
10/22/17 07:30 PM
10/22/17 07:30 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Originally Posted By pittsburghracer
Did anyone ever check to see if ATI makes a 727 aftermarket case. My ATI
Case is very heavy duty and comes with a steel safety liner that slides down into the pump
Somebody could make them but I have never seen an aftermarket 727 or 904 case. I would sure like a SFI approved 904 case.
Bill
Re: 727 explosion at Milan last night.... [Re: dustergirl340] #2391447
10/22/17 09:19 PM
10/22/17 09:19 PM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
How do the Carbon Fiber shields hold up to an explosion. I have one on the shelf to go in over the winter.
Re: 727 explosion at Milan last night.... [Re: 80fbody] #2391449
10/22/17 09:27 PM
10/22/17 09:27 PM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
There was a pic posted on here yrs ago. It got pretty tore up but, I don't thing the driver go hurt. With a billet drum, shield & smart driving worries should be over.
Re: 727 explosion at Milan last night.... [Re: rickraw] #2391476
10/22/17 10:13 PM
10/22/17 10:13 PM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
Ya, a billet drum is gonna be on my list when I go trans brake in the near future hopefully.
Re: 727 explosion at Milan last night.... [Re: dustergirl340] #2391630
10/23/17 06:10 AM
10/23/17 06:10 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
It can get expensive to upgrade the 727. I used the A&A Ultimate sprag ($195), Billet Steel front drum ($550), Billet aluminum rear drum ($250) Note this was mostly for clearance with the billet front drum. Billet Steel 4-pinion front planetary gear ($499) The splines in my stock aluminum gear were cracked and falling out. CRT reverse manual valve body with low band apply ($275). That is $1769 to start with. A modified race pump with max lug gears ($315), lightened sun shell ($165), Deep aluminum trans pan ($175), billet front servo ($83.00), 4.2:1 band lever ($25), Billet strut ($19), billet strut anchor ($34), Billet low reverse servo ($48), billet accumulator (), rebuild kit(), alto read eagle clutches and kolene steels(), vent relocation (), Bands (), more stuff I forget...
Re: 727 explosion at Milan last night.... [Re: 451Mopar] #2391633
10/23/17 07:16 AM
10/23/17 07:16 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
A good drum and a decent valve body will last forever in a low 10 second car with stock components. My 9.0 car runs stock 3 pin planet carriers, pump gears, shafts, and servos, Factory 518 truck pan, 3.8 stock lever. You can reinforce the stock strut with 10 minutes work, same with modifying the pump feed, relocating the vent. Rabestoes tan clutches in my low 10 second car went over 1000 passes. In fact the only non stock components were a Turbo Action non/LBA valve body, good drum, deep truck pan.
Doug
Re: 727 explosion at Milan last night.... [Re: dustergirl340] #2391641
10/23/17 09:39 AM
10/23/17 09:39 AM
Minn
SportF Offline
SportF  Offline
Minn
It can get expensive to be safe, yep.
That is also why the A&A race trans, all in one package, are a pretty good deal. And he has several levels of race trans.
"Speed costs money, how fast do you want to go?"
But in this case, even a 14 second ride can hurt you real bad.
Re: 727 explosion at Milan last night.... [Re: dustergirl340] #2391701
10/23/17 11:26 AM
10/23/17 11:26 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Doug pretty much nailed it.... got a street/strip ride, put the drum in.
Re: 727 explosion at Milan last night.... [Re: J_BODY] #2391717
10/23/17 11:54 AM
10/23/17 11:54 AM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
I did that 2 years go, billet drums are cheap compared to the loss of a foot.
72 Plymouth Roadrunner 11.08@123.25
Re: 727 explosion at Milan last night.... [Re: dustergirl340] #2391718
10/23/17 11:58 AM
10/23/17 11:58 AM
an8sec70cuda Offline
Doesn't look like the blanket did a very good job of containing it w/ the size of the hole in the floor.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 727 explosion at Milan last night.... [Re: an8sec70cuda] #2391726
10/23/17 12:19 PM
10/23/17 12:19 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
My bet is that straps that go to the bell housing bolts were too long or not installed allowing the blanket to slide rearward.
Doug
Re: 727 explosion at Milan last night.... [Re: dvw] #2391736
10/23/17 12:32 PM
10/23/17 12:32 PM
Doug
Probably so. Or if it was a Lofgren Blanket, which only has 2 straps that wrap around/under the trans, the straps were either damaged or the transmission broke apart so there was nothing for it to hold onto.
CHIP
Re: 727 explosion at Milan last night.... [Re: an8sec70cuda] #2391740
10/23/17 12:39 PM
10/23/17 12:39 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
^^ This, I didn't get a pic, but when they jacked the car up, the blanket emptied out like a coin purse.
I will be upgrading my drum this winter and swapping to a LBA VB
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: 727 explosion at Milan last night.... [Re: dustergirl340] #2391834
10/23/17 03:04 PM
10/23/17 03:04 PM
MD
JACK1440 Offline
JACK1440  Offline
MD
I just recently upgraded the drum when we went to the new motor (although that's back in the shop) I've been running stock trannies for a long time and these posts scared me into that drum and bolt in sprag. Hate to see these things happen. At least it was at the starting line and not headed down the track.
Re: 727 explosion at Milan last night.... [Re: dustergirl340] #2391835
10/23/17 03:04 PM
10/23/17 03:04 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Do you suppose if this guy could go back in time and spend $1200 to make his tranny explosion proof, would he do it?
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
