Just put both the red and black wires under the same post of the meter. Bypasses the meter and maintains a closed circuit. No cutting, no splicing, no problems.
Might want to add a voltmeter on the bottom of the dash or someplace. Can tap off of the same post of the ammeter that the two wires are on for the hot lead to the voltmeter. Then just ground the other voltmeter lead.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, .
Moparmarks Parts & Restorations
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/motormangj@gmail.com
