The wires are the wiring from your truck, they connect to those posts. I have done this on several trucks, I just snip the ends and solder them together and wrap with heat shrink. Bypass it all!
Thank you. If I don't do what T2R9 did right away, I'll at least do this until I do so I don't melt anything in the mean time. I do like what he did so I'll probably do that eventually anyway.
