I opwend a lot of them I disconnected the amp gauge on all of them.Then used a volt meter.Just as said disconnect the battery.Pull the gaue palen for it and disconnect the wires.I just used a screw and nut then taped the heck ouy ot them and put it all back.Never a problem You can also put both on one side of the gauge.Rocky
