Thank you moparmarks. I was thinking of adding voltmeter in a semi-discrete place (I like the clean stock look) so I will do as you advise with wire.
Thanks again for valuable information.
Larry
For a stock look add the factory voltage and vacuum gauge to the left side of your dash. There is set on eBay right now (not mine) a bit pricey if you look around at swap meets you will find a deal on a set of gauges.
77 Dodge Adventurer SE 440 2wd SWB 78 Dodge Adventurer SE 440 2wd Utiline 90 Dodge D150 SWB 2wd 318fi 4speed 60 Desoto Adventurer 2dr 67 Dodge Dart Gt Conv. 273 4bbl 04 PT Cruiser GT Turbo 14 Ram R/T "Life's to short to drink cheap beer."
