good call on the psi & even tho it was a hi vol pump (not sure what spring), that number sure kinda points to minimal overall leakage. Evidently they did not mock it up/mike clearances after they did their work as he ended up plastigaugeing it himself (that had been bothering me from early on). I'm gonna see if I can drive up to the machine shop & take a look at the carnage.
