Re: engine siezed, any thoughts on why
[Re: Twostick]
#2164638
09/29/16 08:23 PM
09/29/16 08:23 PM
Posts: 9,883 MI, usa
dvw
MI, usa
Its a spun Main, and nothing else. A seized piston, crank can still move abit, clearances n bearings. A siezed cam bearing, crank can still move with chain slop. A vert bolt stuck to block, crank should still be able to move backwards, at least with a breaker bar. Besides the described sounds weren't right. A bad vert, no way. You would still be able to get some kind of crank movement. A spun rod bearing, crank can still move there too, clearances. A spun Main,Yep, Locked up Tight. So , there is my Out on the limb, Big Fat limb opinion. ![work work](/ubbthreads/images/graemlins/custom/work.gif) Good news though, is there wont be a lot of carnage. he drained the oil & said it looked OK, he cut open the filter & said there was some "fine" metallic particles, nothing disturbing. Could be bearings but I would expect more shrapnel in the filter. I have seen a front pump seized up solid. Thought it was the crank until they tried to separate the engine from the trans. Took a 6 foot bar to get it apart. If the trans is good my bet is still pistons. Kevin When mine jammed the converter bolt, the motor would not budge in either direction with a breaker bar and a pipe. Didn't really hurt anything except the bolt and the threads in that hole in the converter. Still has same flex plate, converter, no block damage,only very slight scratch. Doug
Entire Thread
RapidRobert
09/24/16 05:17 PM
killermopar
09/24/16 05:41 PM
62maxwgn
09/24/16 05:52 PM
killermopar
09/24/16 05:55 PM
RapidRobert
09/24/16 06:24 PM
Cab_Burge
09/24/16 06:49 PM
RapidRobert
09/24/16 06:53 PM
BSB67
09/24/16 07:33 PM
Morty426
09/24/16 07:46 PM
RapidRobert
09/24/16 09:30 PM
fast68plymouth
09/25/16 12:03 AM
RapidRobert
09/25/16 12:26 AM
Challenger 1
09/25/16 01:18 AM
RapidRobert
09/25/16 01:22 AM
Sxrxrnr
09/25/16 07:13 AM
RapidRobert
09/25/16 07:29 AM
Jim_Lusk
09/25/16 08:49 AM
rumblebee4232
09/25/16 02:50 PM
62maxwgn
09/25/16 02:58 PM
6PakBee
09/25/16 03:33 PM
RapidRobert
09/25/16 04:33 PM
dogdays
09/26/16 07:23 PM
RapidRobert
09/26/16 09:00 PM
R/T1968R/T
09/27/16 01:00 AM
RapidRobert
09/27/16 01:37 AM
Sxrxrnr
09/27/16 02:02 AM
RapidRobert
09/27/16 06:33 AM
Twostick
09/27/16 02:25 AM
Sxrxrnr
09/27/16 08:39 AM
RapidRobert
09/27/16 05:03 PM
DrCharles
09/28/16 01:04 AM
Rhinodart
09/28/16 01:20 AM
RapidRobert
09/28/16 04:31 AM
Morty426
09/28/16 04:36 AM
Twostick
09/28/16 04:44 AM
RapidRobert
09/28/16 04:46 AM
Cab_Burge
09/28/16 08:56 AM
3hundred
09/28/16 01:37 PM
justinp61
09/28/16 04:32 PM
Neil
09/28/16 08:22 PM
RapidRobert
09/28/16 09:37 PM
Cab_Burge
09/29/16 07:02 AM
dvw
09/28/16 01:44 PM
killermopar
09/28/16 09:44 PM
Sport440
09/29/16 01:19 AM
Twostick
09/29/16 01:53 AM
dvw
09/30/16 12:23 AM
Sxrxrnr
09/29/16 08:11 PM
stat5
09/29/16 08:34 PM
RapidRobert
09/30/16 02:34 AM
RapidRobert
10/09/16 03:46 AM
SomeCarGuy
10/10/16 06:27 AM
poorboy
09/29/16 03:42 AM
Sport440
09/29/16 03:51 AM
RapidRobert
09/29/16 04:32 AM
Porter67
09/29/16 07:30 AM
Sxrxrnr
09/29/16 10:38 AM
Twostick
09/29/16 05:53 PM
Evil Spirit
09/29/16 06:34 PM
gdonovan
10/10/16 12:21 PM
knuckelbuster
10/14/16 02:31 AM
NANKET
10/14/16 04:44 AM
RapidRobert
10/14/16 06:26 AM
FurryStump
10/14/16 10:02 PM
FurryStump
04/08/17 05:09 PM
NANKET
10/14/16 11:07 PM
RapidRobert
10/15/16 12:04 AM
gdonovan
10/22/16 11:27 AM
FurryStump
10/15/16 04:46 PM
RapidRobert
10/16/16 03:07 AM
fastmark
10/22/16 12:42 PM
wingman
10/22/16 03:09 PM
RapidRobert
10/22/16 05:10 PM
TJP
10/22/16 05:21 PM
HemiSportFury
10/22/16 05:27 PM
RapidRobert
10/22/16 05:55 PM
6PakBee
10/22/16 07:17 PM
NANKET
10/22/16 06:58 PM
Stroker
10/22/16 08:20 PM
RapidRobert
10/23/16 01:52 AM
Fat_Mike
10/23/16 05:37 PM
RapidRobert
10/23/16 05:53 PM
RapidRobert
10/24/16 04:13 AM
JohnRR
10/24/16 06:20 PM
RapidRobert
10/24/16 06:36 PM
justinp61
10/22/16 08:21 PM
topside
10/23/16 04:01 AM
fastmark
10/23/16 12:35 PM
fastmark
10/24/16 01:39 PM
RapidRobert
10/24/16 06:13 PM
fastmark
10/24/16 06:32 PM
dodgeboy11
10/24/16 08:35 PM
fast68plymouth
10/24/16 11:51 PM
JohnRR
10/25/16 05:05 PM
RapidRobert
10/26/16 06:57 AM
JohnRR
10/26/16 04:49 PM
RapidRobert
10/26/16 05:55 PM
62maxwgn
10/26/16 07:49 PM
RapidRobert
10/27/16 12:42 AM
Sport440
10/27/16 01:51 AM
RapidRobert
10/27/16 02:01 AM
JohnRR
10/27/16 04:10 PM
screamindriver
10/27/16 08:40 PM
Brian_wo
11/06/16 01:56 AM
rumblebee4232
11/16/16 04:20 AM
NANKET
11/16/16 04:23 AM
skicker
11/16/16 04:32 AM
gdonovan
12/09/16 02:38 PM
RapidRobert
12/09/16 03:56 PM
Re: engine siezed, any thoughts on why. UPDATE!
RapidRobert
04/07/17 05:51 AM
1971 Gran Coupe
04/07/17 06:42 AM
RapidRobert
04/07/17 06:56 AM
srt
04/07/17 07:03 AM
RapidRobert
04/07/17 07:50 AM
justinp61
04/07/17 02:24 PM
6PakBee
04/07/17 02:57 PM
3hundred
04/07/17 03:27 PM
RapidRobert
04/07/17 05:34 PM
Porter67
04/07/17 02:57 PM
fast68plymouth
04/07/17 05:20 PM
poorboy
04/08/17 03:13 AM
GMP440
04/08/17 02:18 PM
qwkmopardan
04/08/17 04:53 PM
dvw
04/08/17 04:16 AM
rhad
04/08/17 06:02 AM
fastmark
04/08/17 05:18 PM
RapidRobert
04/09/17 01:45 AM
HUSTLESTUFF
04/15/17 01:38 PM
RapidRobert
04/15/17 04:51 PM
