He undid the rockers and then he is trying to turn the engine over ??
And he is surprised the engine is hard to turn over ???
I think he means...... If you unbolt the rockers...... And don't remove the spark plugs......they turn over pretty hard.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123
Dealer for Comp Cams/Indy Heads
