Originally Posted By Cab_Burge
No need to unbolt the trans, remove the dust cover and then the four converter bolts and see if the starter spins the converter or not twocents
Cab, I can see him getting to two bolts if he's lucky. With the engine or whatever is stuck how would he get to the others?
