Since you mentioned blued cap and clearances checked: any chance the bearing saddle of either the cap or block had an edge ding.
Motor ran fine until heat built to the point of bearing failure.
I'm coming in late and I'd be suspect of foreign material in the bearing interface, or dome sort of block or cap defect displacing bearing.
Be interesting to find out how difficult assembly rotation was prior to start-up.
