Originally Posted By ngpSatellite
Originally Posted By B5XP29
Here's my 5.2/5.9 Magnum TV cable that replaced my clunky 3-piece throttle pressure linkage setup. Just had to make a small bracket for the arm of the carb, and weld it to the throttle cable bracket. Also used the Magnum TV lever and mounted the cable to the factory ear on the 727, just as it was on the 46RE it came off of
Anyway you could show a picture of the transmission hookup?? Nice setup!! I have a 67 383 727 TF with the stock setup and would like to change it to your setup.
Thanks!!
Any part number for the TV cable??
that would be the only correct cable type setup to consider using in my opinion. just make sure of the geometry correctness at the carb linkage connection and at the transmission lever.
beer
