Here's my 5.2/5.9 Magnum TV cable that replaced my clunky 3-piece throttle pressure linkage setup. Just had to make a small bracket for the arm of the carb, and weld it to the throttle cable bracket. Also used the Magnum TV lever and mounted the cable to the factory ear on the 727, just as it was on the 46RE it came off of
Anyway you could show a picture of the transmission hookup?? Nice setup!! I have a 67 383 727 TF with the stock setup and would like to change it to your setup.
