Here's my 5.2/5.9 Magnum TV cable that replaced my clunky 3-piece throttle pressure linkage setup. Just had to make a small bracket for the arm of the carb, and weld it to the throttle cable bracket. Also used the Magnum TV lever and mounted the cable to the factory ear on the 727, just as it was on the 46RE it came off of
1969 Nova 454/M21/3.31 Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD 5.0/4R70W/3.55 (Daily driver)
