How many of you have checked adjusted the movement on the inside of the transmission on the valve body? Mine needed adjustment there also which I did when I had the pan off.
67 Dart GT 340 4 speed 70 AAR Cuda 408 6 barrel 96 Indy Ram original owner 2011 Hemi Durango
