I think the Stock and Lokar setup only moves the KD lever rearward and allows slack in the linkage when at idle. When I received my Lokar kickdown, the cable sheath was too long to work correctly, so I had to remove the inner cable and cut the outer sheath shorter to get the correct amount of movement in the cable.
