Here is the thing many miss, even the guys with Cal-Traks, ladder bars, struts, 4 links, whatever. The car does NOT ride bad because you have one of the above for suspension. It rides bad because MOST people grossly overspring their car. You put log wagon springs on it, don't be surprised when it rides like one. Guys with cal-tracs, it's NOT the bars that makes it ride rough, it's the spring. The rear segment of the spring is what the car rides on, with bars and if it rides really hard, you have too stiff a rear segment most likely
