Is this a track only car or a street car? I'm running two passenger side 2800lbs SS springs in bith my 3700lbs A-Body and similar weight E-body. They are the perfect spring rate for street use.
For a track only car, I would have used the specific left & right side springs to flatten out the body lean on hard launch.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
