Originally Posted By 70Cuda383
The browning happens with ALL white letter tires that I'm aware of. Bleach White spray and a scrub brush when you wash the car will bring them back to pristine white again
Agreed, any white letter tire and whitewall would brown after a while, belted or radial from any decade of mfg...generally I use Tri-Chlorethelene to whiten the whitewalls/letters to a bleached white condition, if you use it, you only apply to the white portion of the wall/letter as it dissolves the black rubber
