Whatever radiator you choose to run, make sure to do a thorough flush out job of your cooling system before installing the new unit. I would even go so far as to advise flushing out the block by removing the drain-cock or a freeze plug and spraying your garden hose in it for a few minutes until the water runs out clean.
Get all the nasty stuff out that will plug up your new unit.
