I worked in a old timey radiator shop in my youth. Your original A-body radiator probably needed riding out as the tubes plug up over time. You wouldn't believe how many old tubes were probably plugged solid... So its likely a new brass radiator would have fixed your cooling problem as well....unless you are saying the radiator was new too? Were they the same capacity/configuration radiator?
Yes, 2 new copper/brass radiators, neither would cool. Aluminum took care of it right away!
