Originally Posted By justinp61
Tale of two cars, father-sons. Sons, 528 all aluminum Hemi with big aluminum radiator, runs over 2 hundred or more, all the time, with two fans and custom made shroud. Fathers, 472 Hemi steel block aluminum heads stock radiator no shroud, like it came off the line, runs 160 all day, any temp outside. 63&65 Dodges. I told him to get rid of the rad. and electric pump, won't listen, steady throwing money at it??
Originally Posted By cudaman1969
[quote=justinp61]Tale of two different cars, apples to oranges.
To the orginial poster, you don't need a high dollar radiator to cool your car. A parts store replacement will work fine. [/quote
Apples to oranges? Only difference is the block, same crank, just bigger bore in the 528, same flat tapet cam.
So both cars have electric water pumps?
No, hot one has a Merzzery or however you spell it. I'm saying that's the problem, do you agree?
