A heat exchanger usually loses efficiency by fouling. Even a very thin layer of something in the tubes can cut the total heat transfer rate by quite a bit.
Agreed...
Just wondering if coolant passing between a cast iron block, and an aluminum rad has a negative effect on the core...
I've got an OEM copper/brass rad that I've been running for over 20 years...
Appears to be little, or no 'fouling' in the transfer tubes looking in from the filler neck...
Still cooling just fine...
