Wonder how the Nichels stock car arrangement would compare. They welded a sleeve into the k-member, screwed in what looked like a typical Mopar ball joint, and joined it to a shortened two piece strut rod, with a threaded collar. A tie rod type adjustment was used to change the length as needed.
