Start at 16-20 initial with a stock camshaft. This should allow you to turn the idle.speed down. Stock cam should idle easily at 750-800 rpm when the set up is right with minimally drop when placed in gear.
The factory specs were not close to optimum as Emissions were a concern.
Don't mess with the accelerator pump until the timing is sorted out.
