First get your timing correct, initial, mechanical advance, vacuum advance and limit your total timing for your tune.
Make sure you have no vacuum leaks and your linkage works perfectly.
Set your float levels, select the proper vacuum pod springs and adjust your jetting and idle A/F settings using a wideband.
It's a bit time consuming and you need to do things in order, but everything you need to know about any specific step is available right here.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
