The compression numbers you give are in complete, are those numbers wet or dry? With a blower you might only have a headgasket issue. Smallblocks are a bit sensitive in that regard compared to a bog block, 4 head bolts per cylinder vice 5.
They say there are no such thing as a stupid question. They say there is always the exception that proves the rule. Don't be the exception.
