Moparts Main Index
| READ -
Info & Help Page
Moparts Sponsors
Tech Archive
Register
Log In
Moparts
Forums
Unlawfl's Race & Engine Tech
Trick Flow Mopar head
Forums
Calendar
Active Threads
Search
Forum Help
Re: Trick Flow Mopar head
Re: Trick Flow
#1912963
09/15/15
01:00 PM
09/15/15
01:00 PM
May 2015
Tallmadge, Ohio
Trick Flow
Trick Flow
May 2015
Tallmadge, Ohio
Here are the specs for the head.
Material: A356-T61 aluminum
Combustion Chamber Volume: 78cc CNC-profiled
Intake Port Volume: 240cc CNC Street Ported
Intake Port Location: Stock
Intake Port Dimensions: 2.270" x 1.230"
Intake Valve Diameter: 2.190"
Intake Valve Seat: Ductile iron
Exhaust Port Volume: 74cc CNC Street Ported
Exhaust Port Location: Stock
Exhaust Port Dimensions: 1.250" x 1.650" oval
Exhaust Valve Diameter: 1.760"
Exhaust Valve Seat: Ductile iron
Valve Angles: 15°
Valve Guide Material: Bronze alloy
Valve Seals: Viton® fluoroelastomer canister
Valve Seat Angles: 45° x multi-angle
Valve Spring Pocket Diameter: 1.615"
Valve Spring I.D. Locators: 1.300"
Valve Spring Retainers: Steel or titanium
Valve Stem Locks: 7° or 10° steel
Valve Springs, Standard: 1.460" o.d. dual spring with damper
120 lbs. @ 1.900" installed height
394 lbs. @ 1.175" open
390 lbs. per inch rate
.650" max. valve lift
Valve Springs, Option 1: 1.550" o.d. dual spring
138 lbs. @ 1.950" installed height
430 lbs. @ 1.250" open
420 lbs. per inch rate
.680" max. valve lift
Valve Springs, Option 2: 1.560" o.d. dual spring with damper
240 lbs. @ 2.000" installed height
600 lbs. @ 1.280" open
500 lbs. per inch rate
.700" max. valve lift
Rocker Arms: Roller rocker arms recommended
Entire Thread
Subject
Posted By
Posted
Trick Flow
09/15/15
03:39 PM
65Fury440
09/15/15
03:50 PM
Trick Flow
09/15/15
04:01 PM
dartman366
09/15/15
04:47 PM
Trick Flow
09/15/15
04:58 PM
BradH
09/15/15
04:45 PM
Trick Flow
09/15/15
05:00 PM
GTX MATT
09/15/15
06:26 PM
Trick Flow
09/15/15
07:34 PM
PorkyPig
09/21/15
06:09 PM
carter
09/22/15
02:13 PM
JohnRR
09/22/15
04:27 PM
DoubleD
09/22/15
04:58 PM
BradH
09/22/15
05:12 PM
AndyF
09/22/15
05:45 PM
70RT Charger
09/27/15
12:53 AM
BradH
09/22/15
05:15 PM
JohnRR
09/22/15
06:44 PM
Criterion
09/15/15
06:44 PM
70RT Charger
09/16/15
01:53 AM
Thumperdart
09/16/15
01:57 AM
PorkyPig
09/16/15
02:17 AM
GomangoCuda
09/16/15
02:28 AM
AndyF
09/16/15
02:47 AM
Trick Flow
09/16/15
02:48 PM
340B5
09/16/15
03:15 PM
70RT Charger
09/16/15
03:05 AM
AndyF
09/16/15
06:44 PM
70RT Charger
09/16/15
10:31 PM
DGS
09/16/15
11:10 AM
Trick Flow
09/16/15
02:47 PM
scottb
09/16/15
03:25 PM
Trick Flow
09/16/15
09:59 PM
J_BODY
09/16/15
03:30 PM
DblOJoe
09/18/15
03:41 AM
Cudajon
09/20/15
06:51 PM
DblOJoe
10/02/15
12:17 AM
Criterion
10/02/15
01:20 AM
BradH
10/02/15
03:35 PM
451Mopar
10/02/15
10:03 AM
70RT Charger
10/02/15
12:50 PM
JohnRR
10/06/15
06:33 PM
Azzkikrcuda
10/06/15
06:55 PM
AndyF
10/06/15
06:59 PM
Criterion
10/02/15
02:22 PM
Bad340fish
10/02/15
03:51 PM
Triple Threat
10/02/15
05:24 PM
Criterion
10/02/15
05:29 PM
BradH
10/03/15
06:32 PM
rickseeman
10/02/15
06:28 PM
LaRoy Engines
10/02/15
06:42 PM
CTD5.9
10/02/15
07:14 PM
JohnRR
10/05/15
12:33 AM
70RT Charger
10/02/15
10:09 PM
BradH
10/03/15
06:11 PM
Skeptic
10/04/15
07:32 PM
70RT Charger
10/04/15
11:35 PM
fast68plymouth
10/03/15
07:22 PM
BradH
10/03/15
07:47 PM
Criterion
10/03/15
07:40 PM
fast68plymouth
10/03/15
08:10 PM
BSB67
10/03/15
08:35 PM
BradH
10/06/15
03:26 PM
fast68plymouth
10/03/15
09:12 PM
AndyF
10/03/15
10:44 PM
MR_P_BODY
10/03/15
10:58 PM
dartman366
10/04/15
12:52 PM
max_maniac
10/04/15
04:25 PM
B3422W5
10/04/15
11:00 PM
pittsburghracer
10/05/15
12:34 AM
MR_P_BODY
10/05/15
02:09 AM
AndyF
10/04/15
12:23 AM
MR_P_BODY
10/04/15
12:25 AM
Airwoofer
10/04/15
04:54 PM
Cab_Burge
10/05/15
02:06 AM
Moparnut426
10/05/15
02:55 PM
64Post
10/05/15
05:14 PM
BradH
10/05/15
05:22 PM
RV2
10/06/15
03:26 AM
Monte_Smith
10/06/15
07:52 AM
BradH
10/06/15
03:12 PM
Roughbird72
10/06/15
05:41 PM
Al_Alguire
10/06/15
08:36 AM
Jerry Kathe
10/06/15
11:46 AM
Jerry Kathe
10/06/15
11:52 AM
Monte_Smith
10/07/15
12:28 AM
BSB67
10/07/15
02:36 AM
Jerry Kathe
10/07/15
03:37 AM
pittsburghracer
10/07/15
03:40 AM
AndyF
10/07/15
06:31 PM
Jerry Kathe
10/07/15
03:48 AM
Al_Alguire
10/06/15
07:09 PM
DblOJoe
10/06/15
07:13 PM
Al_Alguire
10/06/15
07:19 PM
GY3
10/06/15
07:21 PM
HotRodDave
10/06/15
08:19 PM
Bad340fish
10/06/15
09:25 PM
AndyF
10/07/15
03:14 AM
Monte_Smith
10/07/15
06:08 AM
Jerry Kathe
10/07/15
12:06 PM
451Cuda
10/07/15
06:18 AM
dart games
10/07/15
08:48 AM
dartman366
10/07/15
09:35 AM
Thumperdart
10/07/15
05:35 PM
pittsburghracer
10/07/15
12:31 PM
tboomer
10/07/15
03:11 PM
d7cook
10/07/15
05:26 PM
1jeff
10/08/15
03:39 AM
JohnRR
10/08/15
05:07 PM
1jeff
10/10/15
01:16 AM
JohnRR
10/11/15
03:51 AM
Moderated by
Al_Alguire
Hotwheelsjr
moparts
not_a_charger
RangerDan440
tboomer
Hop To
Moparts Question and Answer ------
Gen III Hemi Tech
Moparts Restoration & A12 Forum
Corners Are Best - Handling Tech
Sandy's Truck Shop
Street Rodders
Stu Harmon General Forum
Moparts Extras ------
Mopar Connection Magazine
Moparts Hot Deals & New Products
Moparts Show Listings
Member Projects & Survivor Pictures
Best of Moparts / Tech Archive
Lost & Found, Clubs, Businesses, Jobs
Transport Services Wanted/Offered
Moparts Free On-Line Swap Meet ------
Ebay / Craigslist / Marketplace / WIW
Moparts A Body
Moparts B Body
Moparts E Body
Moparts Full Size
Modern Moparts Muscle
Moparts Truck / Vans / Jeep / Willys
All Other Moparts / AMC
Classic/Streetrods/Hotrods - 1961 and Before
Moparts Race Cars / Parts/Tools/Trailers
Moparts Engines
Trade/Swap/Free/ & Brand X
Transmission and Differential
Moparts Wheels / Tires
Moparts Memorabilia
Switch to Flat Mode
View Profile
Send Private Message
View Homepage
Follow User
Show Forum Posts
Default Style
infopop2
moparts
RealmHQ
sd.DarkDoom
ubbcentral.classic
UBBT77
ubbthreads
ubbthreads-dark
ubbthreads-light
ubbthreads L Type
Privacy Policy
Forum Rules
Mark All Read
Contact Us
Moparts
Moparts Main Index
| READ -
Info & Help Page
Moparts Sponsors
Tech Archive
