Once someone has a good flowing hand ported set then its the number of steps/transitions that is involved.. I had a set of CNC heads done(W-9s) then had them flowed... then I went over them with hand bits... it picked up 3 CFM on the mid to full lift... same numbers down low.. but I will say there was some big steps/transitions per step
