Quote: I think most of you are missing the point, what is the cost of I beams? what is the cost of H beams? is it really worth it?
You implied in that statement that if you can get an H beam for the price of an I beam, why wouldn't you do so. IMO, same weight rod to same weight rod, of same material, the I beam has some strength benefits. Btw, are you aware the Scat I beams are 4340 forgings, The Eagle SIR rods are 5140
