Hey thanks Roe, I need the passenger side door trim piece and if you ever come across them I need a cargo light lens cover and an interior dome light cover. They are just cheap plastic but scarcer then hens teeth.
For some reason not too many 1st Gens are around here in the pick and pulls (Missouri Ozarks not too far from Ft Leonard Wood).
If you ever come across them I will send you the cost plus postage and some of the Mrs Blackberry jam.
