Few more pics. Since the last pics I have finished DA'ing the exterior of the car. I built a sandblasting booth in the shop and started blasting the motor compartment today. Things worked great but after I used the 100lb bag of sand I bought I re-used the stuff on the floor. I must have got some garbage in there because it plugged up instantly. I'll fix that tomorrow.
Here is the fancy blasting booth. Took about 40 minutes to put up.
Here is the exterior of the car.
This is how far I got with 100 lbs. Both inner fenders and part of the firewall.
