The Indybrocks ARE offset. Stock small block rockers DON'T fit them So one is required to buy some form of BIGBLOCK rocker to fit them because of the 150 offset they have that a stock small block head doesn't have So if you buy Indybrocks you have to buy something you wouldn't have as a small block guy And if you are using a performance cam you are going to end up with big block Harland Sharps or some other rocker, just like you would use on any quality build
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, low 10.30’s 1/4 1.41 best 60 foot 6.56 at 104.17
