(Pitsburghracer) Do you mind listing your engine and car details.
As accurate as possible. weight, gearing, trans type, headers, conv stall.
engine specs. comp, gas, special ring pac, vacuum pump, carbs, intake, fuel octane, ect, ect.
THANKS.
Nothing special 74 360 block .040 over with a Hughes 4" crank, H beam rods,diamond 51005 pistons(over 5 years old).016 deck height and a bullet cams roller 504000 275 at 50 duration .683 lift with 1.6 Hughes roller rockers. Crane roller lifters, Super victor intake, old 9375 dominator, custom headers and a preform distributor. Trans is a glide with a pro tree trans brake and a barrowed 5000 stall. It has 32x14 tire with 6.30 gears(I think. I can look for receipt if you want to know) in a 9". I should be able to run pump 93 but use 110 from the track. The car is a 97 tube chassis Avenger that weights 2340. Best pass so far is a 5.78 with 1.20 sixty foot at 118. From what I'm seeing racing cars faster than mine I have faster sixty footers and mile per hour but they have faster ets so I think it has more but I haven't had time to tune any more. I have it set to shift at 7400 and crossing the line around 7200 in the 1/8th
